[mapguide-users] Re: Popup info on data with Google Maps
asexternalprovider
Berg, Leandros van den [FGSBV]
L.vdBerg at fugro.nl
Fri Feb 10 07:00:39 EST 2012
Hi Martin,
I assume then you have created the application within MapGuide Maestro
by adding an Application Definition resource and selecting the Slate
template. In that case, when you open the resource in MapGuide Maestro,
at the top of the screen there is a button 'Edit as XML'. At the bottom
of the XML Editor you'll find the GoogleScript element. Don't forget to
press Save and also save the resource again.
Kind regards,
Leandros
