[mapguide-users] ECW - Fail to get image information
Zac Spitzer zac.spitzer at gmail.com
Fri Feb 17 08:52:37 EST 2012
see http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg16920.html
On Sat, Feb 18, 2012 at 12:40 AM, Hans Milling <hm at geograf.dk> wrote:
> Hi all
> Using MGOS2.2 and Maestro i am trying to create a layer with an ECW file.
> But it does not work (preview turn up with a white background), i see the
> below errors in the log file. I have tried to use a folder with many smaller
> ECW files and just using one big ECW file, it is the same result. The ECW
> file works in MGOS2.0 and AIMS2012. The rest of the layers in the map are
> show as always (also tried with just one ECW layer).
> Does anyone have a clue what the problem might be?
> Best regards
>  Hans Milling...
> <2012-02-17T14:02:59>   2912    Ajax Viewer     ::1     Administrator
>  Error: Failed to stylize layer: Orthofoto2008-1
>        An exception occurred in FDO component.
>        Fail to get image information.
>  StackTrace:
>  - MgMappingUtil.StylizeLayers() line 831 file
> c:\builds\mg22win32\mgdev\server\src\services\mapping\MappingUtil.cpp
> <2012-02-17T14:23:10>   2744    MapGuide Maestro v4.0.0.6359    ::1     Administrator
>  Error: An exception occurred in FDO component.
>        Only MOSAIC(), CLIP() and RESAMPLE() are supported.
>  StackTrace:
>  - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>  - MgOpSelectFeaturesSpatial.Execute() line 110 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>  - MgServerFeatureService.SelectAggregate() line 541 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\ServerFeatureService.cpp
>  - MgServerSelectFeatures.SelectFeatures() line 266 file
> c:\builds\mg22win32\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
> <2012-02-17T14:23:14>   1208    Ajax Viewer     ::1     Administrator
>  StackTrace:
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-Fail-to-get-image-information-tp4480118p4480118.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
