[mapguide-users] Re: FeatureSource has a different coordinate
system than the map
Zac Spitzer
zac.spitzer at gmail.com
Sat Feb 25 02:31:43 EST 2012
it all depends on your data
rivers are often supplied with low level accuracy, if you are viewing
them at a high scale mapguide needs to read all the data and then
scale it to make it visible. i.e. lots of processing
you may need to generalize your data for different view scales
how does it go at lower scales like 1:5000 ?
On Sat, Feb 25, 2012 at 9:38 AM, Lotte Doyle <doylelotte at gmail.com> wrote:
> Ahh, this did the trick! I usually go for stable builds and thought 2.1 was the latest from what was listed on the Downloads page.
> I'm still monitoring the cpu load and see that it still takes quite a lot of processing power for every map UI action, though the maps no longer freeze. Is this normal?
> On 2012-02-17 14:56, Zac Spitzer wrote:
>> 2.1 is an old release, 2.2 is much more stable
>> http://trac.osgeo.org/mapguide/wiki/Release/2.2/Notes#Installation
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
