[mapguide-users] MapGuide 2.2 GDAL Raster Provider - a little help finding some files
Matt McLean mmclean at cgis.com
Wed Jan 4 14:43:35 EST 2012
Thanks for the response!  Actually, I just got a response from Tamas who
had an old copy of the file that I was looking for.  I'm going to give it a
go before resorting to trying with a newer, or custom build of GDAL.  Good
to know that you've had good luck with your own builds if I need to go that
route.
Thanks again.
On Wed, Jan 4, 2012 at 1:25 PM, Gabriele Monfardini <gabrimonfa at gmail.com>wrote:
> > Problem is that the file is no longer available on Tamas' site.  Does
> anyone
> > have a copy of this file kicking around that they could send my way?
> >  Alternatively, can anyone confirm if a newer build would work - and be
> > stable?
> I'm on Linux and for some reasons I have to compile gdal myself.
> I've compiled and used (in production sites) version 1.6.0, version
> 1.6.3 (last release in 1.6 branch if I remember correctly) and version
> 1.7.2, without particular problems on tiff and png rasters (even if
> some care is required preparing the files, and I strongly suggest
> testing the files with gdalinfo prior to deploy it).
> I've also tried version 1.8 from SVN some times ago and had some
> problems with mapguide. At the time I had not enough time to
> investigate the reason, also because version 1.7 appered to run well.
> I've compiled it passing the parameter (--with-thread), that for
> versions below 1.8 is not the default, in order to have multithread
> support.
> So probably a correctly compiled gdal 1.6 or 1.7 for windows is going to
> work.
> Regards,
> Gabriele Monfardini
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120104/8a1c9982/attachment.html
