[mapguide-users] Re: Modify Map with base layers before load?
Jackie Ng
jumpinjackie at gmail.com
Tue Jan 10 20:04:10 EST 2012
The resource id of the Map Definition factors into the physical path on the
server where the rendered tiles are stored in, so having a session-based Map
Definition with tiled maps is somewhat meaningless as subsequent
session-based Map Definitions will resolve to different physical paths for
the tile cache.
What wrong (or what's stopping you) from adding layers to your runtime map
after loading the WebLayout?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Modify-Map-with-base-layers-before-load-tp7171738p7174490.html
