[mapguide-users] Re: MaestroAPI: Can't use LocalNative Connection
from API in trunk
Jackie Ng
jumpinjackie at gmail.com
Fri Jan 13 09:41:58 EST 2012
I've changed how Maestro.LocalNative is setup post-4.0. It's now hard
referenced against the version of MapGuide it supports (currently only MGOS
2.2 and 32-bit). I plan to include the LocalNative library project as part
of the SDK so you can roll your own LocalNative connection assembly for your
particular version of MapGuide/AIMS instead of going through this assembly
binding redirection business.
One of these changes is changing the name of the implementation assembly so
that you know what version of MapGuide the assembly is supposed to be used
against. The implementation assembly has changed to
OSGeo.MapGuide.MaestroAPI.Native32-2.2.0.dll
As you can guess, it is for MGOS 2.2 and is 32-bit
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MaestroAPI-Can-t-use-LocalNative-Connection-from-API-in-trunk-tp7184159p7184213.html
