[mapguide-users] Fusion right click menu
elliott17
elliottd at ae.ca
Tue Jul 3 12:34:25 PDT 2012
I made the two changes to select.js contained within the fusion\widgets
folder. The same behaviour is evident prior to editing the file in that no
right click menu shows up when using the selection icon.
My file looks like the following now:
activate: function() {
this.handler.activate();
//this.shiftHandler.activate();
this.getMap().setCursor(this.asCursor);
* deactivate the widget (listen to mouse events and change cursor)
* This function should be defined for all functions that register
* as a widget in the map
deactivate: function() {
this.handler.deactivate();
//this.shiftHandler.deactivate();
this.getMap().setCursor('auto');
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-right-click-menu-tp4984285p4985774.html
