[mapguide-users] MG 2.4 RC1: PostGIS objects not selectable
von Wartburg, Jan BKSD
Jan.vonWartburg at bl.ch
Tue Jul 17 02:44:47 PDT 2012
Thanks Jackie, now it works!
Just a side note on FDO Toolbox 1.0:
When connecting to a PostgreSQL/PostGIS feature source, the option "Config Document Path" is not available (greyed out), so the XML file with the overrides cannot be attached there.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, July 17, 2012 10:49 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MG 2.4 RC1: PostGIS objects not selectable
I would've told you to configure the PostgreSQL feature source with a schema override, but Maestro's editors don't support configuring RDBMS feature sources in an easy way.
So you'll have to do it like this:
http://themapguyde.blogspot.com.au/2010/09/using-fdo-schema-overrides-redux.html
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/MG-2-4-RC1-PostGIS-objects-not-selectable-tp4988731p4988763.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
