[mapguide-users] coordinate conversion 2.4 RC1 (google epsg:3785)
Jackie Ng
jumpinjackie at gmail.com
Fri Jul 20 23:45:21 PDT 2012
If it is for the purpose of showing your map with google/bing/osm layers
lining up then, the map should be in WGS84.PseudoMercator, whose wkt is:
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular
Visualisation Pseudo
Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/coordinate-conversion-2-4-RC1-google-epsg-3785-tp4989752p4989765.html
