[mapguide-users] MG2.4 Feature Source FDO Error 559 - Connect Failed
geomapper tedghill at gmail.com
Mon Jul 23 11:46:10 PDT 2012
Greetings,
I am currently running MG Version 2.4 x64 on IIS running PHP, which I have
just upgraded to from MG 2.2. My problem is due to a number of data
connections which were previously working properly, but now appear to be
broken or improperly linked.
Below is the error message given by the log files when I tried to "Test
Connection" for an SDF Feature Source in Maestro (I recieve similar messages
when trying all other data connection types too):
<2012-07-23T09:26:55> 	2016	MapGuide Maestro v4.0.1.6639	127.0.0.1
Administrator
 Error: An exception occurred in FDO component.
        Error occurred in Feature Source
(Session:ea537b66-d4e1-11e1-8000-005056b67e2c_en_MTI3LjAuMC4x0AFC0AFB0AFA//8b9df030-9b59-49b5-a02e-f1744f1a87bb.FeatureSource):
        SDF connect failed. File does not exist or cannot be opened in
specified access mode.
        - MgFdoConnectionManager.Open() line 333 file
c:\mg-2.4-x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
        - MgFdoConnectionManager.CacheFdoConnection() line 1099 file
        - MgFdoConnectionManager.Open() line 1091 file
         (Cause: , Root Cause: )
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgServerFeatureService.TestConnection() line 243 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
  - MgFdoConnectionManager.Open() line 368 file
>From what I understand, my main issue is that the files mentioned in the
error message actually do not exist on my computer, as I have been unable to
locate them. I have also checked the FDO directory in the MapGuide
installation, and all of the correct DLLs appear to be there, as well as the
providers.xml document which looks correct. I am presuming either an error
on my part when installing MG2.4, or an error with the 2.4 installer on my
machine is to blame; although I believe the former to be more possible since
I am still new to MGOS. On that note, my apologies if this is a trivial
error.
Can anybody please advise me about what the next best steps to take would
be?
Sincerely,
Thom
View this message in context: http://osgeo-org.1560.n6.nabble.com/MG2-4-Feature-Source-FDO-Error-559-Connect-Failed-tp4990167.html
