[mapguide-users] GDAL provider dlls
Steve G stevenlgolden at gmail.com
Wed Jul 25 10:48:08 PDT 2012
Using MGOS 2.4.0.6757 and Maestro 5.0.0.6768 and trying to add a new feature
using the GDAL provider.  I am getting the following error (same error
message if I try to open a GDAL resource previously created):
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider library '.\GRFPProvider.dll': The specified
module could not be found.
System.Exception: The remote server returned an error: (559)
MgFdoException.:
 ---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
   at System.Net.HttpWebRequest.GetResponse()
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
c:\Program Files (x86)\Jenkins\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1305
   --- End of inner exception stack trace ---
1321
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
provider) in c:\Program Files (x86)\Jenkins\jobs\Maestro
1746
   at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
trunk\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 60
   at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
trunk\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:line 63
   at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\Program Files (x86)\Jenkins\jobs\Maestro
trunk\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 95
   at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 164
   at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
trunk\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 232
The provider is listed in 'providers.xml' and GRFPProvider.dll is in the
server\Fdo folder.  When I do a depends on the GRFPProvider.dll, it shows
that the GDAL16.DLL cannot be found.  Has the GDAL provider dll been updated
to use gdal 1.9?  Any other cause of the error message?
Thanks,
Steve
View this message in context: http://osgeo-org.1560.n6.nabble.com/GDAL-provider-dlls-tp4990850.html
