[mapguide-users] Can you add a layer with XY coordinates to a Bing maps layer?
Jackie Ng
jumpinjackie at gmail.com
Fri Jun 1 02:14:17 PDT 2012
If British National Grid can be re-projected by MapGuide into
WGS84.PseudoMercator, then yes.
Simple way to test. Add your XY layer into a Map Definition set to
WGS84.PseudoMercator. If you see points on that map, MapGuide has
successfully re-projected them.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Can-you-add-a-layer-with-XY-coordinates-to-a-Bing-maps-layer-tp4978484p4978486.html
