[mapguide-users] MapBase Layer & WMS Layers are not in the same extention
Zac Spitzer zac.spitzer at gmail.com
Fri Jun 1 02:17:30 PDT 2012
have you included proj4js?  just setting a projection like below does nothing
in openlayers unless you include proj4js,
http://trac.osgeo.org/openlayers/wiki/Documentation/Dev/proj4js
z
On Fri, Jun 1, 2012 at 7:15 PM, Nimrod Cnaan <nimcnaan at hotmail.com> wrote:
> Which Projection do you mean,
> I only use the local projection, which is the same value boath on MG map
> defenition & on OpenLayers.
> Am I missing something ?
> var israeliTM = new OpenLayers.Projection("EPSG:2039");
>  // CREATE MAP
>  map = new OpenLayers.Map({
>      div: "map",
>      theme: null,
>      projection: israeliTM,
>      units: "m",
>      numZoomLevels: 18,
>      maxResolution: 1000,
>      maxExtent: new
> OpenLayers.Bounds(195274.029329347,746598.11556093,207935.664746013,743854.386394263),
>      scales: [80000,50000,20000,10000,5000,2500,1250,500,250,100],
>      controls: geomind_controls,
>      layers: geomind_layers,
>      center: new OpenLayers.LonLat(client_data.base_layer.center_lon,
> client_data.base_layer.center_lat), // IN ITM COORDINATES
> View this message in context: http://osgeo-org.1560.n6.nabble.com/MapBase-Layer-WMS-Layers-are-not-in-the-same-extention-tp4978472p4978487.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
