[mapguide-users] incompatible coordinate systems creating a buffer
Marcelo Bilezker marcebil at gmail.com
Thu Jun 7 09:42:58 PDT 2012
I am Usiing MapGuide Open Source 2-2, MapGuide Maestro 4-0
When creating a buffer, I get this message:
1 layer was excluded from buffer computation because its
coordinate system is incompatible with the coordinate system of the map, or
because it has no coordinate system at all
I saw this problem posted before, but I did not managed to see the solution.
(I don't know if the solution was posted, or not, but I did not found it)
I am using Coordinate System:   (Argentina - Faja6)
PROJCS["FAJA-6",GEOGCS["POSGAR",DATUM["POSGAR",SPHEROID["GRS1980",6378137.00
0,298.25722210],TOWGS84[0.0000,0.0000,0.0000,0.000000,0.000000,0.000000,0.00
000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTI
ON["Transverse_Mercator"],PARAMETER["false_easting",6500000.000],PARAMETER["
false_northing",0.000],PARAMETER["scale_factor",1.000000000000],PARAMETER["c
entral_meridian",-57.00000000000000],PARAMETER["latitude_of_origin",-90.0000
0000000000],UNIT["Meter",1.00000000000000]]
When I run the Sheboygan example it works fine, but If I use my own example,
it throws this error.
I was debugging the "Buffer.php" file that comes in the phpsample directory.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120607/d1f8d69a/attachment.html>
