[mapguide-users] [MGOS 2.2] compatibility x64 win 2008 apache
Zac Spitzer
zac.spitzer at gmail.com
Fri Jun 15 19:41:53 PDT 2012
it all depends on your maps, with that amount of users,
you will have to use tiled maps to maintain performance
in terms of bandwidth, it depends on the image format you
are serving... JPEG, PNG8 is much smaller than PNG
in terms of bandwidth.
raster is currently single threaded, so if you are serving raster,
you will face a big bottleneck there, if you need this, i'd suggest
donating towards this project
http://www.otxsystems.com/community-initiatives/gdal-provider-initiative.html
for 100 concurrent users, i would looking at a quad core server
with lots of cores, say minimum 6, aka 24 cores
you will need to tune your maps to be very fast for a single user if you
want to scale up to 100 users
On Sat, Jun 16, 2012 at 1:33 AM, ClaireCG57 <claire.rouy at cg57.fr> wrote:
> Hi!
> So now the server with MGOS 2.4 is installed in a test environnement. I have
> to prepare the production environnement and I don't know which configuration
> is required.
> I think we will have 600 users per day, and max 100 simultaneaous users at
> the opening of the site. What do you think about this config:
> CPU: ???
> RAM 16 Go
> Network
> Connection 100Mbps
> bandwidth 200Mbps
> Regards,
> Claire
> View this message in context: http://osgeo-org.1560.n6.nabble.com/MGOS-2-2-compatibility-x64-win-2008-apache-tp4958094p4981752.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
