[mapguide-users] Hyperlink in Selection panel
Ryan Northcott
rnorthcott at gmail.com
Thu Jun 28 03:47:31 PDT 2012
If you populate the data as a link the properties panel won't render the data as a hyperlink. Just text.
The recommendation to modify the template files and code behind JavaScript is the best option. Just make sure to create backups of any files you change!
- sent via mobile iOS5
On 2012-06-27, at 9:10 PM, Martin Morrison <martin.morrison at edsi.com> wrote:
> Why not just prepopulate the data with valid HTML?
> Martin'
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] on behalf of GIS4U [johnniegis at gmail.com]
> Sent: Wednesday, June 27, 2012 5:09 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Hyperlink in Selection panel
> We modified the propertyctrl.templ (on a site by site basis) to look for a specific property name (ie 'Township') and if it finds it, set the value of a variable to something like:
> var testStr = 'http://www.myserver.com/townshipplans/files/TOWNSHIP-LINK/' + (+properties[i].value) + '.pdf';
> and then fill the value in the table to that variable wrapped in an anchor tag.
> Hope that helps,
> Jonathon
> On Wed, Jun 27, 2012 at 10:09 AM, elliott17 <elliottd at ae.ca<mailto:elliottd at ae.ca>> wrote:
> I realize this topic has been discussed before but I cannot find a solution.
> Is there a way of adding a hyperlink to the selection panel. I want to be
> able to call a report page (asp or pdf or a generic web page). I can get a
> report page to open using the URL feature for a layer when the object is
> hovered over.
> MGOS 2.2 running a fusion layout IIS 7 on Server 2008
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Hyperlink-in-Selection-panel-tp4984293.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
