[mapguide-users] Translate fusion template tabs in FR
Iulia Tamas iulia_tamas30 at yahoo.com
Mon Mar 5 03:55:14 EST 2012
Thank You, Leandros
The problem is solved after adding the file 'MapGuide\Web\www\localized\en' to 'fr'
Iulia
 From: "Berg, Leandros van den [FGSBV]" <L.vdBerg at fugro.nl>
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Friday, March 2, 2012 11:29 AM
Subject: RE: [mapguide-users] Translate fusion template tabs in FR
Hi Iulia,
You also need to copy the file 'MapGuide\Web\www\localized\en' to 'fr',
otherwise it defaults to 'en' when it can't be found. To force MapGuide
to use 'fr', add '&locale=fr' to your url. If there are still some
strings not translated, check your application definition and/or your
template file. Don't forget to restart the web server or application
pool when you made changes to the files.
Kind regards,
Leandros
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120305/afead5d6/attachment.html
