[mapguide-users] Re: Getting started issue
Hans Milling hm at geograf.dk
Tue Mar 6 05:18:11 EST 2012
Try to enter http://localhost/mapguide/mapagent/mapagent.fcgi in your
browser. Where localhost is the name of your server and mapagent is the name
of your application (open the IIS manager to check the name).
If you get an error message, that could lead you to the problem.
A common problem is that CGI is not enabled/installed in IIS or that the
handler mappings are not set correctly.
Try to follow this guide:
http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
The latest version btw. is 2.2, you should be using that instead. The front
page is a bit outdated.
Best regards Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/Getting-started-issue-tp4546986p4550784.html
