[mapguide-users] Re: MapGuide and Windows Web Server 2008
Hans Milling hm at geograf.dk
Tue Mar 6 06:43:44 EST 2012
I have no experience with Web or Datacenter editions but with the standard
edition it works just fine (MGOS 2.2 that is). Also virtual machines work
with no problems.
I guess since nobody answers that they too have little or no experiencw with
the Web or Datacenter edition. Maybe you should just give it a go and try. I
don't expect that there will be any problems since the different editions
are just made to handle different amount of memory, connections etc and
different default instaled components. If you are going to have a server
with 10 users during the day, a standard edition will do just fine, however
if you have a server with thounsand of visitors each hour and memory heavy
web applications a Datacenter edition that supports up to 2 TB of memory
will perhaps be better.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-and-Windows-Web-Server-2008-tp4534244p4550985.html
