[mapguide-users] Re: OGR2OGR with SQL Saptial and f_tables
GordonL
gordon.luckett at arrowgeomatics.com
Thu Mar 8 19:49:30 EST 2012
You would have to update all references to the F_ tables if you want mapguide
to see that table anyway. I would recommend using a new database to load
your files directly.
The downside is that you can't take advantage of the F_ schemas for lookup
tables/etc.
If you already have that table definition in the F_ tables you should be
able to just update the existing table, as long as the coordinate system and
all the fields are the same. Make sure the F_ table names and columns match
what is in the new table (even field types).
View this message in context: http://osgeo-org.1560.n6.nabble.com/OGR2OGR-with-SQL-Saptial-and-f-tables-tp4555593p4560582.html
