[mapguide-users] Changed shape columns cause problems
David Das Neves
neves at systemtechnik.net
Mon Mar 12 05:05:57 EDT 2012
Hello all,
i have a problem which one of you may have got in touch with.
I have set in the Maestro a Shape by a Shape folder. Afterwards i created the different Layers by pointing on the created shape.
Now i have some changes in the shp-Files like some new or changed columns.
If i open the Layer in the Maestro the new or changed columns are updated correctly but i cannot save it because It causes an error:
Failed to find schema Default:xyz in the featureresource xyz
Even if i make the changes in the xml the data can not be shown in the mapview.
For testing purposes i created a new configuration pointing on the new layer with the new/different columns and configurated it like it was before.
This way somehow works but results in a lot of extra work for every layer.
Does someone have a better solution for me how to get changed layers to work?
Best regards
David
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120312/632ea98b/attachment.html
