AW: [mapguide-users] Changed shape columns cause problems
David Das Neves neves at systemtechnik.net
Mon Mar 12 06:06:36 EDT 2012
Ok i got some improvement here.
I turned off validation on saving. Afterwards i opened the layer and looked at the columns(layer properties visible in viewer). The new columns were inserted correctly but the deleted ones were not deleted in the layer.
So I tried to purge the cache. After getting a ServerIsMakingMeAngryAndResourceIsBusyException i restarted the service for the mapGuide and purged afterwards the cache for the shape and the layer which this time worked properly.
Now I opened the layer and the columns were correctly set.
So I tried to validate the layer but the validation is anyway incorrect.
For testing purposes i opened the mapview and looked if the layer is shown correctly. And there it is - visible.
Then i tried to select single objects of the layer and ... no information is shown in the property pane. So it seems that it is still something wrong with the columns in the layer.
Greetings
David
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
Gesendet: Montag, 12. März 2012 10:20
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Changed shape columns cause problems
you just need to resave or flush the featuresource in mastro, the schema info is cached, hence your problem
On Mon, Mar 12, 2012 at 8:05 PM, David Das Neves <neves at systemtechnik.net> wrote:
> Hello all,
> i have a problem which one of you may have got in touch with.
> I have set in the Maestro a Shape by a Shape folder. Afterwards i
> created the different Layers by pointing on the created shape.
> Now i have some changes in the shp-Files like some new or changed columns.
> If i open the Layer in the Maestro the new or changed columns are
> updated correctly but i cannot save it because It causes an error:
> Failed to find schema Default:xyz in the featureresource xyz
> Even if i make the changes in the xml the data can not be shown in the
> mapview.
> For testing purposes i created a new configuration pointing on the new
> layer with the new/different columns and configurated it like it was before.
> This way somehow works but results in a lot of extra work for every layer.
> Does someone have a better solution for me how to get changed layers
> to work?
> Best regards
> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
