[mapguide-users] Re: error on the map
Gabriele Monfardini
gabrimonfa at gmail.com
Wed Mar 14 10:05:49 EDT 2012
> Ok it seems that bad image requests are being made, causing the request
> failure handler (containing the alert() calls) to be called.
> I think you can just remove the alert() calls from ajaxmappane.templ
some days ago I've opened a bug to propose exactly the same solution
http://trac.osgeo.org/mapguide/ticket/1969
Regards,
Gabriele
