[mapguide-users] Google Earth 6.1 Issues
Jason Birch
jason at jasonbirch.com
Thu Mar 15 21:11:13 EDT 2012
Do you have an example of the KML that is being generated? Google Earth
6.1 tightened up its parsing of geometry / coordinates considerably, so if
MapGuide isn't generating them to spec this would be understandable.
I too am using GeoREST for KML generation. Far more flexible and powerful,
though it requires a bit more work in initial setup.
Jason
On 19 January 2012 12:05, Flipper wrote:
> I am having issues viewing Mapguide Created KML in Google Earth 6.1
> Data for Lines and Polygon Borders Appear only as Vertexes...
> They actually look like individual line Vertexes Extruded on the Map.
> I have Tried to edit the settings for the layer in Google Earth, All the
> settings look correct. I tried changing the elevation/altitude as well as
> clamp to ground etc...No Luck
> I have Gone into Maestro and Tried to Set different KML elevations from 0
> to
> 30, extrusions, Absolute, Ground, etc...These do not take in Google
> Earth...They are their if I try to override the layer to Relative to
> ground...But still no line segments.
> ANYONE?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120315/707cbf64/attachment.html
