[mapguide-users] Re: FDO OGR provider stops working with many
layers
Zac Spitzer
zac.spitzer at gmail.com
Tue Mar 20 20:18:14 EDT 2012
given this occurs in AIMS2012, I would suggest raising this with
Autodesk Support
On Wed, Mar 21, 2012 at 12:56 AM, Hans Milling <hm at geograf.dk> wrote:
> I finally had some time to test this.
> I have now tested on AIMS2012 and MGOS2.2. Both fail after about 100 to 180
> layers in a map. It seems like some buffer/file handle problem since it
> always fails at the same layer but if you delete a few layers from the map,
> it fails at another layer.
> MapInfo and OGRInfo tool reports no problem with the .tab/.id/.ind/.map
> files. Also using Maestro I have opened each individual layer and previewed
> them with no problems.
> MGOS2.2 and AIMS2012 then reports "FDO Exception. Connect failed":
> I can still connect to Maestro but the OGR provider does not work at all
> until restart of the MGOS2.2 server.
> In AIMS2012 I see something interesting in the log file, it looks like a
> file cannot be opened by the service (even though the file is there).
> Perhaps some maximum open files limit is reached or something. See error
> below. Also the service therefor does not work at all, after this (need to
> restart the service).
> Any other suggestions would be nice!
> <2012-03-20T14:36:17> 528 MapGuide Maestro API v4.0.0.6359 ::1
> Administrator
> Error: Cannot open repository: C:\Program Files\Autodesk\Autodesk
> Infrastructure Map Server
> 2012\Repositories\Session\ab906dec-7291-11e1-8000-08002700eca5_en_7F0000010B060B050B04.dbxml
> The repository is already opened by another process (e.g. If you are
> running the server interactively as an application from the command line,
> are you also running the server as a service?).
> StackTrace:
> - MgSiteServiceHandler.ProcessOperation() line 83 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\site\SiteServiceHandler.cpp
> - MgOpCreateSession.Execute() line 109 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\site\OpCreateSession.cpp
> - MgServerSiteService.CreateSession() line 762 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\site\ServerSiteService.cpp
> - MgServerResourceService.CreateRepository() line 541 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\resource\ServerResourceService.cpp
> - MgSessionRepository.MgSessionRepository() line 76 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\resource\SessionRepository.cpp
> - MgRepository.VerifyAccess() line 87 file
> d:\build\mge2012\build_42.2\ent\os\server\src\services\resource\Repository.cpp
> Best regards Hans Milling...
> View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-OGR-provider-stops-working-with-many-layers-tp4358864p4636789.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
