[mapguide-users] Re: Google Earth 6.1 Issues
Jason Birch jason at jasonbirch.com
Wed Mar 21 01:51:38 EDT 2012
You'd be better off taking a MapGuide render of a few different geometry
types options (extrusion, etc) and running them through the Galdos KML
Validator to see what MapGuide is doing wrong.
http://kmlvalidator.com/home.htm
The GeoREST generator outputs KML geometry to spec, and the rest is up the
the individual template author to get right; it's just as likely to be
non-compliant as anything.  If the validator doesn't catch it, then it's
likely that MapGuide is getting the KML winding order wrong.
Here's one of mine that validates if it helps:
http://maps.nanaimo.ca/data/property/115545.kml
In my opinion, the MapGuide KML implementation will take more than a
geometry fix to be truly functional. A bandaid solution would be OK for
current users, but IMO what it really needs is a complete overhaul or
deprecation.
Jason
On 20 March 2012 18:46, Jackie Ng wrote:
> It would be nice to have some test cases where the KML generated by
> MapGuide
> differs from the KML generated by GeoREST so we can see where the KML
> renderer in MapGuide is doing it wrong.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120320/54094cf9/attachment.html
