[mapguide-users] Re: FDO OGR provider stops working with many
layers - SOLVED
Zac Spitzer
zac.spitzer at gmail.com
Wed Mar 21 05:41:15 EDT 2012
ah ok, so it only happens when using maestro? that's interesting
so you never preview a layer etc in a web browser?
On Wed, Mar 21, 2012 at 8:37 PM, Hans Milling <hm at geograf.dk> wrote:
> Hi Zack
> I have not tested with any viewer yet. I only worked with maestro so far to
> setup the feature sources, layers and maps, and that was when I discovered
> the problem.
> The problem is solved now thanks. I excluded the OGR provider from the
> connectionpool (Using the DataConnectionPoolExcludedProviders) and now
> everything works. I could see that the pool limit was set to 200, and that
> number is close to the limit found by my test application (even though the
> test application does not use mapguide). I guess that some internal limit is
> reached when more than 200 MapInfo files (Each consists of a TAB, ID, IND
> and MAP file) are opened at the same time. Increasing DataConnectionPoolSize
> did not help, but excluding the provider did.
> Hans...
> View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-OGR-provider-stops-working-with-many-layers-tp4358864p4640016.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
