[mapguide-users] Strange tooltip behavior
Rachot Moragraan moo at ci.garden-grove.ca.us
Fri Mar 23 11:34:29 EDT 2012
We have the same problem here with the similar set up. We also cannot select a layer based on a PG view.
It would seem that because the mapguide pg fdo cant fetch the primary key information for a view it is unable to "select" it on the map.
I would assume it is a similar issue with tooltip.
Our solution has been to create a materialized view instead. Being an actual table, we can create primary keys and mapguide seems to recognize that fine.
Currently we create triggers on associated tables to update the materialized view. In the future, I believe the PG team will have a builtin / automated method for this.
If anyone knows a better solution, please share! I would love to know too!
----- Original Message -----
To: mapguide-users at lists.osgeo.org
Sent: Friday, March 23, 2012 2:47:33 AM
Subject: [mapguide-users] Strange tooltip behavior
I have a layer from a postgresql datasource of multipolygons on which i
define a tooltip (I use Maestro)
Tooltip pops up correctly when i move -strictly over- the polygon.
Now I create a view (inside my postgresql db) with my geometric data table
of polygons and other data from different table.
Polygons are drawn correctly, but tooltip pops up also at a "buffer"
distance around them!! The buffer (about 12 mm on video) is independent to
the zoom.
The problem remains even if my postgresql view is banal (select * from
tblA).
(server Mapguide opensource 2.2 32 bit on win 2008 64; postgresql 9.1 32bit;
client XP, firefox or iexplorer)
Another question: Elements are selectable in the first case (datasource from
table with primary key numeric ecc...). How can i get selectable the
elements from the banal view (select * from tblA)?
Thanks
Giuseppe.
Giuseppe
View this message in context: http://osgeo-org.1560.n6.nabble.com/Strange-tooltip-behavior-tp4648040p4648040.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
