[mapguide-users] Dumb question
Ryan Northcott
rnorthcott at gmail.com
Fri Mar 30 08:12:47 EDT 2012
Have you tried manually modifying the measurement Tool task pane code behind template file to hard code it to always use feet or convert your measurements so the output becomes feet.
Then you can keep your projection in whatever you want for DD coordinates to appear in the taskbar.
I think something like that is the solution... Modify the measure tool and keep your map coordinate system consistent.
-Ryan
- sent via mobile iOS5
On 2012-03-30, at 12:32 AM, "Jacob Maggard" <jacob.maggard at gmail.com> wrote:
> RE: [mapguide-users] Dumb question
> Apologies, but I have a rollout deadline and this still isn't fixed.....need
> help!
> I'd like to be able to render coords in the status bar as DD and measure in
> feet at the same time, without switching over.
> I can set base coord units to feet (using ViewOptions XML) and the tool will
> then measure in feet. Then, if I switch units during that session (perhaps
> to see DD coords), there is no way to get back to measure in feet without a
> full service refresh.
> Coordinates in feet do not mean much to users when we are in WebMercator.
> I cannot set the measure tool itself to feet in its XML......it's as if it
> disregards that entry.
> If we have coords in degrees, the best it seems we can do is switch to
> imperial miles for measurement. In that case, it won't calc area.
> (http://forums.autodesk.com/t5/Autodesk-MapGuide/Measure-Widget/m-p/3366317#
> M3229)
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Thursday, March 29, 2012 10:43 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: FDO OGR provider stops working with many
> layers
> Add the OGR provider to the DataConnectionPoolExcludedProviders setting in
> serverconfig.ini
> - Jackie
> http://osgeo-org.1560.n6.nabble.com/FDO-OGR-provider-stops-working-with-many
> -layers-tp4358864p4669906.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
