[mapguide-users] Re: Sorting within query results
Jackie Ng
jumpinjackie at gmail.com
Mon May 14 11:10:35 EDT 2012
This gets a bit tricky because you now have to query the capabilities XML of
the underlying feature source and you have to look in the capabilities XML
for a particular element (I believe it's
<SupportsSelectOrdering>true</SupportsSelectOrdering>)
If you find this element, it means the FDO provider for that feature source
says ordering is supported, then it is safe to call SetOrderingFilter() in
the MgFeatureQueryOptions.
Also ideally from a safety standpoint, your sort ordering field in your UI
should be enabled/disabled based on this capability check, to prevent
illegal user actions like specifying sort ordering on a Feature Source that
does not support ordering.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sorting-within-query-results-tp4968350p4974480.html
