[mapguide-users] Fusion Spanish localization
Jackie Ng jumpinjackie at gmail.com
Sun May 27 03:11:15 PDT 2012
The problem is that the english strings are "compiled" into the
fusionSF-compressed.js
To have your spanish strings recognised, you have to do a subversion
checkout of the fusion source.
The source for fusion can be found here: http://trac.osgeo.org/fusion/
Drop your string bundles into the "text" folder, then build a new
fusionSF-compressed.js with Apache ant. This one will include your spanish
strings, which will be picked up if you pass in locale=es
For actual localization of the Application Definition document, you can use
Maestro's translate function to do that.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-Spanish-localization-tp4977176p4977198.html
