[mapguide-users] SDFComponentToolkit.dll on 64Bit
Iulia Tamas
iulia_tamas30 at yahoo.com
Wed May 30 05:40:41 PDT 2012
The application type is Class Library and we use the netload command to charge the result dll in AutoCAD.
If we compile the application x86 => the dll result is also 32bit. The probleme is that AutoCAD is 64bit and when we use the netload command we get an error in AutoCAD's command line
Iulia
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, May 30, 2012 3:29 PM
Subject: Re: [mapguide-users] SDFComponentToolkit.dll on 64Bit
Just set your Visual Studio to compile your application as x86, then on 64
bit windows the application will run in 32 bit mode and will be able to
load/run the 32 bit dll file.
Hans...
View this message in context: http://osgeo-org.1560.n6.nabble.com/SDFComponentToolkit-dll-on-64Bit-tp4978012p4978027.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120530/933fd1b0/attachment.html>
