[mapguide-users] Autodesk Infrastructure MapServer - WMS requiring credentials
Sergey Proforov proforov at neolant.ru
Wed May 30 12:42:40 PDT 2012
Hi, how did you connect to WMS servise?
Did you connect with studio "feature source data connection" or with
Map3D, or another product?
There is an error in default configuration of wms service in AIMS 2012
(iis configuration), when you can see published wms layers, but can't
connect.
Look at file c:\Program Files\Autodesk\Autodesk Infrastructure Map
Server 2012\Wms\OgcWmsService.config.awd
at  39 line, port must be set properly, my port is 80, but as default
it was 8008.
 <Define item="SERVER_NAME">localhost:80</Define>
Connection url must be http://localhost/mapserver2012/mapagent/mapagent.fcgi
2012/5/30 Flavio Hendry <flavio at tydac.ch>:
> Hi Sergey
>> Try to use wms/wms, and see to the end of webconfig.ini file at
>> mapserver2012 virtual folder source path.
> Thanks ... yeah, according to the administration setup, userid of WMS is
> "WmsUser" and according to webconfig.ini "wms" is the password ... I saw
> that, but nothing works (not wms/wms, not WmsUser/wms not even admin
> credentials ...) ... In addition, according to the admin setting, anyone
> should have access anyway (no credentials should be required).
> Mit freundlichem Gruss / Best regards
> Flavio Hendry
> TYDAC Inc.  - http://www.tydac.ch
> Web Mapping - http://www.mapserver.ch
> Swiss Maps  - http://www.mapplus.ch
> ############      Mit freundlichen Gruessen / Kind Regards
> ############     Flavio Hendry, CEO - mailto:flavio at tydac.ch
> ############         TYDAC AG - http://www.tydac.ch
> ####    ####        Geographic Information Solutions
> ####    ####       Optingenstrasse 27 -- CH-3013 Bern
> ############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
>   Location: http://www.mapplus.ch/adr/bern/optingenstrasse/27
Сергей Профоров;
ЗАО "Неолант";
skype:proforov
email:proforov at gmail.com
