[mapguide-users] Popup info on data with Google Maps as external provider
Zac Spitzer zac.spitzer at gmail.com
Thu May 31 00:36:44 PDT 2012
I have filed a task to track this in the fusion trac
http://trac.osgeo.org/fusion/ticket/526
if you need a fix, you can checkout and build your own version
of fusion from source and update and test it with openlayers 2.12
On Wed, May 30, 2012 at 11:03 AM, ilyasselk <ilyasselk at gmail.com> wrote:
> SO Can someone give me the code used before changing it to (in the past
> solution) :
> <GoogleScript>http://maps.google.com/maps/api/js?sensor=false</GoogleScript>
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Popup-info-on-data-with-Google-Maps-as-external-provider-tp4376251p4977892.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
