[mapguide-users] Autodesk Infrastructure MapServer - WMS requiring credentials
Łukasz Kuras lukasz.kuras at gmail.com
Thu May 31 15:18:21 PDT 2012
Hello Flavio,
First of all check at Site Administrator if mapserver is listening on
right adress and port:
http://<server_name>/mapserver2013/mapadmin/wmsproperties.php >
Configure WMS.
The Server Name field should contain FQDN or ip address of the server
including port for web service, eg. 192.168.111.18:80.
Check also Script name field for appropriate path, eg.
/mapserver2013/mapagent/mapagent.fcgi (I'm using 2013 version of AIMS
so don't be confused).
Using Infrastructure Studio check permissions for map and related
resources (in properties window). Usually it's a read/write access for
everyone (inherited from parent).
Also remember that the correct path for WMS service in ADSK Map server
contains a question mark and the end, eg.
http://192.168.111.18:80/mapserver2013/mapagent/mapagent.fcgi?
Could you tell exactly what do you mean by 'can't connect'? You can't
contact server at all or can't list the published layers?
Best regards,
Łukasz Kuras
Technical support division
phone. (+48 42) 28 81 633
mobile. (+48) 605 848 266
fax. (+48 42) 25 03 119
email lukasz_kuras at aplikom.com.pl
www.aplikom.com.pl
________________________________________
APLIKOM Sp. z o.o.
94-104 Łódź, ul. Obywatelska 137
POLAND
2012/5/31 Flavio Hendry <flavio at hendry.ch>:
> Hi Sergey
> Thanks again. We connected with various software using the url
> http://localhost:port/mapserver2012/mapagent/mapagent.fcgi such as:
> - get capabilities in browser
> - MapInfo Pro
> - AIMS using a data connection
> We tried that on three different installations, two at our office and one at
> a client site. The connection works, the only thing is that it's always
> asking for credentials. We contacted Autodeks support ... let's see what
> turns out.
> Mit freundlichem Gruss / Best regards
> Flavio Hendry
> TYDAC Inc.  - http://www.tydac.ch
> Web Mapping - http://www.mapserver.ch
> Swiss Maps  - http://www.mapplus.ch
> ############      Mit freundlichen Gruessen / Kind Regards
> ############     Flavio Hendry, CEO - mailto:flavio at tydac.ch
> ############         TYDAC AG - http://www.tydac.ch
> ####    ####        Geographic Information Solutions
> ####    ####       Optingenstrasse 27 -- CH-3013 Bern
> ############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
>   Location: http://www.mapplus.ch/adr/bern/optingenstrasse/27
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
