[mapguide-users] Autodesk Infrastructure MapServer - WMS requiring credentials
Łukasz Kuras lukasz_kuras at aplikom.com.pl
Thu May 31 15:15:07 PDT 2012
Hello Flavio,
First of all check at Site Administrator if mapserver is listening on right
adress and port:
http://<server_name>/mapserver2013/mapadmin/wmsproperties.php > Configure
WMS.
The Server Name field should contain FQDN or ip address of the server
including port for web service, eg. 192.168.111.18:80.
Check also Script name field for appropriate path, eg.
/mapserver2013/mapagent/mapagent.fcgi (I'm using 2013 version of AIMS so
don't be confused).
Using Infrastructure Studio check permissions for map and related resources
(in properties window). Usually it's a read/write access for everyone
(inherited from parent).
Also remember that the correct path for WMS service in ADSK Map server
contains a question mark and the end, eg.
http://192.168.111.18:80/mapserver2013/mapagent/mapagent.fcgi?
Could you tell exactly what do you mean by 'can't connect'? You can't
contact server at all or can't list the published layers?
Best regards,
Łukasz Kuras
Technical support division
phone. (+48 42) 28 81 633
mobile. (+48) 605 848 266
fax. (+48 42) 25 03 119
email  <mailto:lukasz_kuras at aplikom.com.pl> lukasz_kuras at aplikom.com.pl
 <http://www.aplikom.com.pl/> www.aplikom.com.pl
  _____
Opis: aplikom_logo_kolor_przezrocz_male
APLIKOM Sp. z o.o.
94-104 Łódź, ul. Obywatelska 137
POLAND
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120601/e8c7a452/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120601/e8c7a452/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120601/e8c7a452/attachment-0001.png>
