[mapguide-users] ECW file with mapguide 2.4 and gdal 1.9
Hans Milling hm at geograf.dk
Fri Nov 2 06:03:50 PDT 2012
I found, that it helps if you apply a coordinate system to the feature source. Leaving it default/empty results in blank preview.
Best regards
  Hans Milling...
Mange <magnus.ek at boliden.com> skrev:
>Hi, we are running mapguide 2.4.0.7096 i.e. latest stable. And I followed
>instructions for the 2.2 version
>(http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider). Though instead of
>choosing the packages compiled for gdal 1.6 I picked the ones for gdal 1.9
>(http://vbkto.dyndns.org/sdk/PackageList.aspx?file=release-1500-x64-gdal-1-9-mapserver-6-0.zip).
>The only dll I did not succeed to find was (lti_dsdk_dll.dll) Though I
>suspect it is a misspell and the proper one should be (lti_dsdk.dll).From
>here I restart mgserver and make a new gdal feature source pointing at my
>%MG_DATA_PATH_ALIAS%\raster.ecw. When testing the connection it seems ok. I
>name this resource "GDALraster"I add an layer pointing at the raster. But
>nothing shows. The preview in maestro is empty as well . Guess I have some
>more debugging to do here...Regards, Mange
>View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-file-with-mapguide-2-4-and-gdal-1-9-tp5013489p5013527.html
>Sent from the MapGuide Users mailing list archive at Nabble.com.
>_______________________________________________
>mapguide-users mailing list
>mapguide-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapguide-users
