[mapguide-users] ECW file with mapguide 2.4 and gdal 1.9
Mange magnus.ek at boliden.com
Fri Nov 2 07:36:18 PDT 2012
Hi! You are right about the coordinate system. I saw a tiny spot in my map
which turned out to be the raster image way to small. Everything seems to be
working with ecw and gdal which is good news!
Now I must figure out how to adapt the proper coordinates and scale. The
shape files I use in my gis app. are in an arbitrary x-y millimetre system
and so should the ecw raster be as well. Together with my ecw file I also
have a world file (eww) with the same name. I am not sure if it is used by
gdal. It contains information about the raster, pixel size 0.05, initial
coordinate in upper left corner is 1759000 and 7186600.
Rgds, Mange
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-file-with-mapguide-2-4-and-gdal-1-9-tp5013489p5013581.html
