[mapguide-users] function ShowFirstClass() in displayschema.php
carls carlshe at 163.com
Mon Nov 5 02:40:23 PST 2012
while previewing a featuresource with displayschema.php, by clicking
'preview' button in Maestro, there will be a warning message at
ShowFirstClass()
       *function Toggle(objId)
            if(document.getElementById(objId).style.display == 'none')
document.getElementById(objId).previousSibling.firstChild.src =
"./images/collapse_pane.png";
                document.getElementById(objId).style.display = 'block';
            else
"./images/expand_pane.png";
                document.getElementById(objId).style.display = 'none';
            document.getElementById("Data_"+"<?php echo
$firstClass?>").previousSibling.firstChild.src =
$firstClass?>").style.display = 'block';
            document.getElementById("Geom_"+"<?php echo
While tracing the code, it could be found the objId in Toggle includes the
schema name, but $firstClass in ShowFirstClass doesn't.
So I wonder the $firstClass is not parsed correctly, or the schema name
should be inserted before $firstClass.
View this message in context: http://osgeo-org.1560.n6.nabble.com/function-ShowFirstClass-in-displayschema-php-tp5013964.html
