[mapguide-users] Getting error "Geometry Conversion error" when doing SpatialFilter in MgCurvePolygon
Gunter Becker
gunter.becker at csogis.de
Thu Nov 15 00:28:31 PST 2012
Simply execute the Union-method before applying your spatial filter:
geometry = geometry.Union(geometry);
That's the way I workaround curve polygons for SQL Server 2008. In case of a
MgCurvePolygon the resulting geometry is a segmented MgPolygon. I don't know
if this is a bug in the library as I would expect also a MgCurvePolygon as
the result but it does a good job for workaround all types of curve
geometries in SQL Server 2008. Maybe this is an OGC conform behaviour of the
Union-method. Don't know!
Curve geometries should be supported in SQL Server 2012 but I am not aware
if the FDO Provider for SQL Server already supports these features. Haven't
tried it yet!
Gunter
View this message in context: http://osgeo-org.1560.n6.nabble.com/Getting-error-Geometry-Conversion-error-when-doing-SpatialFilter-in-MgCurvePolygon-tp5014745p5016513.html
