[mapguide-users] Fusion - how to set the hyperlink to open in the taskpane?
Jacqueline W jackiejwoodruff at gmail.com
Sat Nov 17 09:50:10 PST 2012
If you are in the Layout Editor, in the Configure Components section look at
the bottom of this area where it says 'Manage all Components'. If you open
this, you can scroll to find an InvokeScript called Maptip. Double Click
this widget and in the 'Target' Property, write TaskPane. The only thing is;
the task pane doesn't open automatically you have to open it or have it open
to start with.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-how-to-set-the-hyperlink-to-open-in-the-taskpane-tp5014070p5017109.html
