[mapguide-users] An exception occurred in DB XML component. Error: Document not found
StuartSteel
stuart.steel at atkinsglobal.com
Fri Nov 30 06:40:41 PST 2012
Jackie,
I'm seeing this on 64bit OpenSource version 2.4.0.7096. In IM Studio 2013
the definition appears to delete, but reappears upon refreshing the site,
whilst in Maestro 5b4 the following message appears in the UI and in the
error log:
Error: Document not found: Library://ab2/Web Layouts/ab2_TB.WebLayout
The resource can be opened up, edited and saved just fine, and then after
re-saving can be deleted normally.
The server is running 2008 R2.
Cheers,
Stuart
View this message in context: http://osgeo-org.1560.n6.nabble.com/An-exception-occurred-in-DB-XML-component-Error-Document-not-found-tp4183873p5019886.html
