[mapguide-users] New Installation - unclear/missing documentation
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Oct 3 02:56:50 PDT 2012
Hi list,
I'm interested in trying MapGuide but am having trouble figuring out what
to download. The 2.4 has a regular and an "instantSetup" but the page
doesn't actually say what the difference is between them is (there's a long
"notes" section that will probably help the installation once I've figured
out what I want to install).
The "documentation" link ( http://mapguide.osgeo.org/documentation.html ) has
nothing newer than 2.0.x with 2.1.x being "TBD".
On - http://mapguide.osgeo.org/GettingStartedResources - There are two IIS7
installers, though the second one "Another IIS7 Installation Page" seems to
be pointing at a parked domain (work has it blocked as such anyway).
Using Windows Server 2008 R2, IIS7.5. Already have PHP and MapServer
installed and working.
Any suggestions on what to do?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121003/873f477a/attachment.html>
