[mapguide-users] 'Select Within' widget error in Fusion
Ilona Kemeling
ilona at kemeling-consulting.com
Thu Oct 11 02:10:05 PDT 2012
All,
I use:
MGOS 2.4
MG Maestro 5.4b
Apache server/PHP
On a Windows 7 pc
But same occurs on
MGOS 2.4
MG Maestro 5.4b
IIS/PHP
On a Windows 2008 server
I keep getting this error message when I try to use the Select Within widget
in fusion map.
When I use a standard layout (not fusion), the Select Within widget works
fine, with exactly the same layers/map definition.
Any help/suggestions are welcome!
Ilona
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121011/843f3067/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121011/843f3067/attachment.png>
