[mapguide-users] utility map backup.sql file
sidecar5 shoemark.peter at gmail.com
Sun Oct 14 23:37:56 PDT 2012
Hi, I'm still on the lookout for an answer to my 'aspx appears as text'
problem but to keep the ball rolling I have been into the MySQL setup. I
have the original discs at work for MGE 2010, AIMS 2012 and 2013 but none of
them have the data (or script) as called by the Autodesk Infrastructure Map
Server 2012 – Overview Scripted Demonstration document.
(utilitymapbackup.sql file) I am assuming the sql provides the data for the
MySQL database.
Any helpers?? Cheers, Peter
View this message in context: http://osgeo-org.1560.n6.nabble.com/utility-map-backup-sql-file-tp5008604.html
