[mapguide-users] cannot change layer attribute field display names in maestro
jtby jbrosowsky at geo-comm.com
Sun Oct 28 08:19:00 PDT 2012
I cannot change layer attribute field display names in maestro.  I change
them in the grid, hit save, but they do not persist.  Feature source is a
shapefile.  Everything else in mapguide and maestro works perfectly.
Using Mapguide 2.2.0.5703 and Maestro 4.0.0.6359.  I have also tried the
newest Masetro version as well with same result.  I have also edited XML
directly via Maestro.  I can change all other attributes of the layer, and
persist changes in maestro just fine.  Just not the field display names.
Any ideas on how to fix it?
Thanks!
View this message in context: http://osgeo-org.1560.n6.nabble.com/cannot-change-layer-attribute-field-display-names-in-maestro-tp5011797.html
