[mapguide-users] King Oracle Layer not selectable.
Crispin_at_Linknode
crispin.hoult at linknode.co.uk
Thu Sep 6 03:06:22 PDT 2012
A few things to try:
1) Obtain the latest KingOracle for FDO 3.5 from SL-King who build older FDO
versions from the latest FDO source code
(http://www.sl-king.com/fdooracle/fdooracle.html)
2) Ensure that in your Oracle tables you have primary keys and not unique
indexes
3) If you happen to be using very long integer numbers (such as big
sequences) then there is an outstanding bug
If everything is working slowly please check that you have appropriate
indexes - selection should be no slower than a map layer refresh.
Crispin
View this message in context: http://osgeo-org.1560.n6.nabble.com/King-Oracle-Layer-not-selectable-tp4999882p5000157.html
