[mapguide-users] How to get selected feature information in popup window
elliott17 elliottd at ae.ca
Tue Sep 11 12:24:47 PDT 2012
I am running php 5.4.6 on Server 2008 with MGOS 2.2 and SQL server 2008 r2.
I have set up a php page to call an image for the Fusion map tip and keep
getting an error (500 internal server error).  I created an identical php
file on the server and it works.  My post message is "Test Test!!
../images/Walls/Mariner Way/sw10/P1020533.JPG Image ID: 25 "
Is there a setting that I am missing to have this work?
My php file is:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<HEAD>
<title>Gregs Test</title>
</head>
<body>
Test Test!!
<?php
$oid = $_GET["ImageID"];
$serverName = "XXXXXX\sqlexpress";
$connectionInfo = array( "Database"=>"database name", "UID"=>"Username to
SQL", "PWD"=>"pwd to SQL");
$conn = sqlsrv_connect($serverName, $connectionInfo);
if(!$conn)
	echo "<br/>Couldn't connect to SQL Server on $serverName";
$result = sqlsrv_query( $conn, 'select URL from wall_lines where OID = (?)
', array( $oid ));
while($row = sqlsrv_fetch_array($result))
	echo($row['URL']);
echo "Image ID: " . $oid;
</body>
</html>
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-get-selected-feature-information-in-popup-window-tp4999139p5001157.html
