[mapguide-users] Plotting to DWF
Jonathan Rizzo
jrizzo at Langan.com
Thu Sep 20 12:29:13 PDT 2012
Hello List,
I seem to be having trouble plotting to dwf. I'm not sure what happened, but somewhere along the way my code broke. My code runs and the result is a DWF file, but whenever I try to open the file in latest version of Design Review, it crashes. I have looked over my code, and I can't figure out what the problem is. Basically, I have a function, plotMap which returns an MgByteReader, and then I use the reader to get a memory stream, and then I write the memory stream to the OutputStream of the HttpResponse. I suspect that I may be inadvertently adding some bad data, but I just don't see it. Are any of you able to do this on your sites? Can somebody point me to a working example of this? Thanks.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
This electronic transmission may contain confidential, proprietary or privileged information. No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120920/267e85fd/attachment.html>
