[mapguide-users] MapGuide Maestro 5.0 beta 4 and 4.0.3 maintenance release available
Jackie Ng jumpinjackie at gmail.com
Thu Sep 27 01:07:42 PDT 2012
That use-case has not been tested :)
Any resource you're editing is a session-based copy of the original
site-based resource, so you're basically editing a session-based copy of a
session-based resource. But it should be okay, Maestro uses guids for
resource names for shadow copies so there shouldn't be the possibility of
the original resource being accidentally trampled over in your particular
case.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-Maestro-5-0-beta-4-and-4-0-3-maintenance-release-available-tp5004353p5004863.html
